Struggling with Enshrouded Dedicated Server Requirements?
« am: 29. August 2025, 16:09:32 »
Hey everyone,
I’ve been digging into enshrouded dedicated server requirements lately because I wanted to set one up for smoother co-op sessions with friends. The challenge is figuring out the right balance between CPU, RAM, and storage so the server doesn’t choke when more players join. From what I’ve seen, the game is pretty resource-hungry, especially if you want low latency and stability.
A lot of people run into issues when they underestimate the specs or choose cheap hosting that can’t handle the load. That’s why I’d recommend checking out providers like HostNoc, since they actually give clear server configuration options tailored to gaming setups. It helps avoid the trial-and-error mess of upgrading later.
If anyone here has tested different setups, what specs worked best for you? I’d like to compare before finalizing my build.
